Volume Priorities
josephmcs
Volume Priorities
Post by josephmcs »
Hello all,
I'm having some problem with glass and water priorities in luxcorerender. Please see the attached image for reference.
I made an "air" volume that is set to priority 5. I set this as the camera volume as well.
The glass of the vessel is set to priority 4.
The water is set to priority 3.
As you can see, the result is not optimal. Does anybody have any idea as to why this might be?
Thank you
Re: Volume Priorities
josephmcs
Post by josephmcs »
I know, but it's not always evident to get a scene below 2mb. Especially with an HDRI, which is pretty vital to this issue. Unfortunately I seem stuck at trimming it down to about 7mb, even after I removed the HDRI. Any suggestions?
Edit: I compressed it! See attached.
new oil test.zip
(881.88 KiB) Downloaded 1466 times
You have messed up the volume in the camera.
the water geometry also have inverted normal.
This what happen when I correct both :
josephmcs wrote: Tue Aug 23, 2022 10:38 pm I know, but it's not always evident to get a scene below 2mb. Especially with an HDRI, which is pretty vital to this issue. Unfortunately I seem stuck at trimming it down to about 7mb, even after I removed the HDRI. Any suggestions?
:o
There are such file hosing sites allowing anyone to send few GBs in a go. ;)
And Sharly, thank you 8-)
josephmcs
Post by josephmcs »
This is very helpful. Thank you so much (and for your kind patience with my test scene uploading issue)
