Problems with alpha texture and mix nodes
denon100
Post by denon100 »
Hello,
I don't know how to use an alpha texture in Luxcorerender
I thought it works like in Cycles ?
Can someone help ?
Thanks
Re: Problems with alpha texture and mix nodes
Looking at the screenshot, you may have to "invert" (i.e. 1 - alpha) the alpha value :idea:
The alpha mask seems the negative of what you want. It should also work if you just swap the mixed materials.
denon100
Post by denon100 »
Even if I swap the materials, I always get an inverted alpha texture.
Do you have any advice ?
Thanks
Can you post the scene ?
denon100
Post by denon100 »
Thank you !
untitled1.blend
(2.31 MiB) Downloaded 1156 times
mip
Post by mip »
Hi Denon,
Maybe, instead of connecting alpha to MixFactor, you could try :
connect SpongeBob Color -> ColorRamp, setting black Offset to 0.9 in ColorRamp
then connect Color Ramp -> Mix Factor
PetrT
Post by PetrT »
This is the way 8-)
denon100
Post by denon100 »
Hello,
this works only conditionally and is not what I want to achieve.
With the user Osmodivs , see link, it also works !
viewtopic.php?f=4&t=2569&p=25335&hilit=alpha#p25335
Thanks
mip
Post by mip »
I think it's because Osmodivs image has a transparent background while yours has a white background.
You will have to use PetrT way or change your source image.
denon100
Post by denon100 »
@PetrT;
you are my hero !
Sometimes you can't see the forest for the trees :idea:
Thanks to all for the help
