I think the U- and V-roughness in my example file were flipped.
I fixed that and I get a result very similar to your Cycles render now.
Does this work for you? File attached.
anisotropic metal UV problem
Re: anisotropic metal UV problem
- Attachments
- aniso2.blend
- (590.4 KiB) Downloaded 843 times
- aniso2_2.8.blend
- (619.2 KiB) Downloaded 902 times
The reflection works fine now but it is still unusable due to artifacts. Mesh is subdivided 4 times and subdividing it 5th time would probably make my computer crash.B.Y.O.B. wrote: Sun Jan 27, 2019 7:24 pm I think the U- and V-roughness in my example file were flipped.
Here is my render:
Looks like your mesh has some problems, or maybe the UV map is not correct?
Can't you just append the disk from my example scene into your project and use it?
I fixed the knob mesh now and it works great. Thanks!B.Y.O.B. wrote: Sun Jan 27, 2019 8:10 pm Looks like your mesh has some problems, or maybe the UV map is not correct?
Nice.
Looks like an interesting scene by the way, will you show it once it's finished?
Sure. It is an analog version of lux render (my first project with this render engine)B.Y.O.B. wrote: Sun Jan 27, 2019 8:55 pm Nice.
lighting_freak
I've tried to apply the given solution on a new mesh.
Working with the same material properties leads to a different render result.
Do you have any idea why?
Left disc is from aniso2.blend, right disc is mine: This is the blend file. BR
OS - Windows 7 X64
CPU - Intel CORE i7
CPU - Intel CORE i7
You might have to mirror or rotate your UV mapping.
It's might be light falling at different angle.
Moved lamp a bit to the right: ~
With a sun lamp:
This is how it looks right now with the real anisotropic shader.B.Y.O.B. wrote: Sun Jan 27, 2019 8:55 pm Nice.
