anisotropic metal UV problem
Re: anisotropic metal UV problem
I think the U- and V-roughness in my example file were flipped.
I fixed that and I get a result very similar to your Cycles render now.
Does this work for you? File attached.
aniso2.blend
(590.4 KiB) Downloaded 732 times
aniso2_2.8.blend
(619.2 KiB) Downloaded 789 times
JoeDDD
Post by JoeDDD »
B.Y.O.B. wrote: Sun Jan 27, 2019 7:24 pm I think the U- and V-roughness in my example file were flipped.
The reflection works fine now but it is still unusable due to artifacts. Mesh is subdivided 4 times and subdividing it 5th time would probably make my computer crash.
Here is my render:
Looks like your mesh has some problems, or maybe the UV map is not correct?
Can't you just append the disk from my example scene into your project and use it?
JoeDDD
Post by JoeDDD »
B.Y.O.B. wrote: Sun Jan 27, 2019 8:10 pm Looks like your mesh has some problems, or maybe the UV map is not correct?
I fixed the knob mesh now and it works great. Thanks!
Nice.
Looks like an interesting scene by the way, will you show it once it's finished?
JoeDDD
Post by JoeDDD »
B.Y.O.B. wrote: Sun Jan 27, 2019 8:55 pm Nice.
Sure. It is an analog version of lux render (my first project with this render engine)
lighting_freak
Post by lighting_freak »
I've tried to apply the given solution on a new mesh.
Working with the same material properties leads to a different render result.
Do you have any idea why?
Left disc is from aniso2.blend, right disc is mine:
This is the blend file.
Disc.blend
(893.72 KiB) Downloaded 772 times
BR
OS - Windows 7 X64
CPU - Intel CORE i7
You might have to mirror or rotate your UV mapping.
wasd
Post by wasd »
lighting_freak wrote: Thu Jan 31, 2019 8:38 am Do you have any idea why?
It's might be light falling at different angle.
Moved lamp a bit to the right:
With a sun lamp:
JoeDDD
Post by JoeDDD »
This is how it looks right now with the real anisotropic shader.
