What is scene.volumes.<volume name>.absorption exactly?
The ratio of power loss of a ray traveling 1 unit through that volume? So glass with a thickness of 1 and absorption of 1 is opaque?
Re: scene.volumes.<volume name>.absorption
Absorption isn't a linear phenomenon, it is exponential (aka Beer’s law): http://www.pbr-book.org/3ed-2018/Volume ... ml#eq:beer (http://www.pbr-book.org/3ed-2018/Light_ ... m-sampling)mick wrote: Mon Feb 04, 2019 11:03 pm What is scene.volumes.<volume name>.absorption exactly?
So it is something like:
Transmittance = Exp(-<absorption> * <distance>)
For a clear volume, you have also to factor scattering for other types (instead of "<absorption>", it is "<absorption> + <scattering>").
You can plug a colordepth texture into the volume's absorption slot for easier usage: https://github.com/LuxCoreRender/LuxCor ... th.cpp#L45
To explain the parameters: kt is the color of white light after travelling the distance d.
Dade, thanks for the reply.
power_out = power_in * e^(-absorption * distance)
So with an absorption of 0.7 a glass plate with a thickness of 1 reduces the radiation from normal angle rays by roughly 50%.
This ignores kt and kr. kt=1 and kr=0 brings full transmission into the volume? At least for normal angle rays?
Is there any documentation about the underlying functions used?
I'm aware that this must be an exponential function. But is it exactly that function with a base of e?
I saw this in blender. But this parameter do not exist in the python API, right?B.Y.O.B. wrote: Tue Feb 05, 2019 11:13 am You can plug a colordepth texture into the volume's absorption slot for easier usage: https://github.com/LuxCoreRender/LuxCor ... th.cpp#L45
Also this not composition is not available via python, is it?
The whole Blender addon is written in Python. Only the mesh and hair export is done in C++, but only because that's faster - you could do it in Python as well. The colordepth texture is available from Python, like any other texture.mick wrote: Tue Feb 05, 2019 7:01 pm I saw this in blender. But this parameter do not exist in the python API, right?
Here's the BlendLuxCore code: https://github.com/LuxCoreRender/BlendL ... __.py#L211
You will have to search for the helper functions "utils.create_props" and "utils.absorption_at_depth_scaled" to see the whole process, but I hope it helps.
It is exactly the same physic used by PBRT (the links I posted). It is probably the best documentation you can find.mick wrote: Tue Feb 05, 2019 6:58 pm Dade, thanks for the reply.
The code for clear volumes is here: https://github.com/LuxCoreRender/LuxCor ... ar.cpp#L70
If you check the Exp() implementation (https://github.com/LuxCoreRender/LuxCor ... lor.h#L178), it is really e^x.
Thanks, Dade. With that references I should be able find out what I need.
Would please also take a look at my other problem: viewtopic.php?f=4&t=903
Thx
Thx
Sorry, I've to come back to this.
does not work for a distance < 1. I would have to specify an absorption > 1, which does neither work in Blender nor LuxCore SDL.
Is there a way to specify an absorption_depth in LuxCore SDL?
Transmittance = Exp(-<absorption> * <distance>)Is there a way to specify an absorption_depth in LuxCore SDL?
scene.volumes.<volume name>.absorption parameter is clamped between [0, +Infinity] so a value > 1 is perfectly legal and usable in LuxCore SDL.mick wrote: Sun Feb 10, 2019 11:24 pm Sorry, I've to come back to this.
does not work for a distance < 1. I would have to specify an absorption > 1, which does neither work in Blender nor LuxCore SDL.Code: Select all
