scene.volumes.<volume name>.absorption
mick
Post by mick » Mon Feb 04, 2019 11:03 pm
What is scene.volumes.<volume name>.absorption exactly?
The ratio of power loss of a ray traveling 1 unit through that volume? So glass with a thickness of 1 and absorption of 1 is opaque?
Re: scene.volumes.<volume name>.absorption
Post by Dade » Tue Feb 05, 2019 11:03 am
Absorption isn't a linear phenomenon, it is exponential (aka Beer’s law): http://www.pbr-book.org/3ed-2018/Volume ... ml#eq:beer (http://www.pbr-book.org/3ed-2018/Light_ ... m-sampling)
So it is something like:
Transmittance = Exp(-<absorption> * <distance>)
For a clear volume, you have also to factor scattering for other types (instead of "<absorption>", it is "<absorption> + <scattering>").
Post by B.Y.O.B. » Tue Feb 05, 2019 11:13 am
You can plug a colordepth texture into the volume's absorption slot for easier usage: https://github.com/LuxCoreRender/LuxCor ... th.cpp#L45
To explain the parameters: kt is the color of white light after travelling the distance d.
mick
Post by mick » Tue Feb 05, 2019 6:58 pm
Dade, thanks for the reply.
I'm aware that this must be an exponential function. But is it exactly that function with a base of e?
power_out = power_in * e^(-absorption * distance)
So with an absorption of 0.7 a glass plate with a thickness of 1 reduces the radiation from normal angle rays by roughly 50%.
This ignores kt and kr. kt=1 and kr=0 brings full transmission into the volume? At least for normal angle rays?
Is there any documentation about the underlying functions used?
mick
Post by mick » Tue Feb 05, 2019 7:01 pm
I saw this in blender. But this parameter do not exist in the python API, right?
Also this not composition is not available via python, is it?
Post by B.Y.O.B. » Tue Feb 05, 2019 7:06 pm
The whole Blender addon is written in Python. Only the mesh and hair export is done in C++, but only because that's faster - you could do it in Python as well. The colordepth texture is available from Python, like any other texture.
Here's the BlendLuxCore code: https://github.com/LuxCoreRender/BlendL ... __.py#L211
You will have to search for the helper functions "utils.create_props" and "utils.absorption_at_depth_scaled" to see the whole process, but I hope it helps.
Post by Dade » Tue Feb 05, 2019 8:15 pm
It is exactly the same physic used by PBRT (the links I posted). It is probably the best documentation you can find.
The code for clear volumes is here: https://github.com/LuxCoreRender/LuxCor ... ar.cpp#L70
If you check the Exp() implementation (https://github.com/LuxCoreRender/LuxCor ... lor.h#L178), it is really e^x.
mick
Post by mick » Sat Feb 09, 2019 3:39 pm
Thanks, Dade. With that references I should be able find out what I need.
Would please also take a look at my other problem: viewtopic.php?f=4&t=903
Thx
mick
Post by mick » Sun Feb 10, 2019 11:24 pm
Sorry, I've to come back to this.
does not work for a distance < 1. I would have to specify an absorption > 1, which does neither work in Blender nor LuxCore SDL.
Is there a way to specify an absorption_depth in LuxCore SDL?
Post by Dade » Mon Feb 11, 2019 8:30 am
scene.volumes.<volume name>.absorption parameter is clamped between [0, +Infinity] so a value > 1 is perfectly legal and usable in LuxCore SDL.
