MayaToLux - Autodesk Maya plugin for LuxCoreRender
Re: MayaToLux - Autodesk Maya plugin for LuxCoreRender
The second shader is almost ready. I think I'll going to use the part of the old exporter and follow the same behaviour as compact all materials in one basic shader.
Lux Rough Glass basics is ready now.
Metal material finished, I hope I'll be able to update the exporter very soon.
I decided to speed up all things a little bit. Here is the result for other shaders.
mate transl
Carpaint
Mirror
Glossy
Light
Null
mate transl
Carpaint
Mirror
Glossy
Light
Null
Very first look at the first object exported by the new plugin.
Here the first Camera object.
You are in RAGE mode apparently guy
Well done. That is inspiring.
Thanks, dude. it'll take a little bit of time to engage people especially plugin is not working yet and there is a long time that luxcore did not support by other software, so many assume it is ended supporting other software.Sharlybg wrote: Sat Apr 17, 2021 8:39 pm![]()
You are in RAGE mode apparently guy![]()
Replacing input fields to more convenient sliders and fixing film sections.
It's a bit slow but it getting shape.
The first test will be after exporting the Meshes.
Hello TAO
Did you get a chance to make some progress with Maya plugin?
I created the first beta version and it works, it has a few issues that I need to solve before uploading the code on the server and publishing the first release.
Considering the difficulty that the main core developer "Dade" mention a few days ago I need to consider a few things before doing more work on the MayaToLux.
Thanks for your patient.
