Denoiser Integration
Very early work in progress, started yesterday...
Re: Secret Thread, Do Not Open!
Cant resist, looks very promising, cool.
Do you use Cycles code or different method?
Cheers, mib
Cheers, mib
WOW
Can I make a suggestion?
Please make it realtime, while you're rendering, not only a postprocess option, because you will never know when you have to stop sampling to get the best results from the denoiser.
Thanks
Thanks
I had the same thoughts.
It is planned to be added as an image pipeline plugin, so you can enable/disable it during rendering (or even after rendering, if you save the film).
We should have sorted out all open problems for BCD integration. Now we have only to write a load of code
This is a 100spp rendering:
More samples per pixels you use and less "splotchy" the rendering will look (BCD is intended for off-line rendering, more samples you have and better it is).
It's already a pure pleasure just to watch you develop... can hardly imagine how it will be working with...
Truly amazing work!
Truly amazing work!
I'm also positively surprised, it works much better than I hoped for.
Is there any word bigger than awesome?
Cannot wait to have this! This could make bidirectional to be the weapon of choice for everyone.
Congrats.
Congrats.
