Denoiser Integration
Very early work in progress, started yesterday... ;)
20 Samples
20 Samples
mib2berlin
Re: Secret Thread, Do Not Open!
Post by mib2berlin »
Cant resist, looks very promising, cool.
Do you use Cycles code or different method?
Cheers, mib
Asticles
Post by Asticles »
WOW
Can I make a suggestion?
Please make it realtime, while you're rendering, not only a postprocess option, because you will never know when you have to stop sampling to get the best results from the denoiser.
Thanks
I had the same thoughts.
It is planned to be added as an image pipeline plugin, so you can enable/disable it during rendering (or even after rendering, if you save the film).
We should have sorted out all open problems for BCD integration. Now we have only to write a load of code :lol:
This is a 100spp rendering:
More samples per pixels you use and less "splotchy" the rendering will look (BCD is intended for off-line rendering, more samples you have and better it is).
It can really work well, this is a 100spp rendering and the denoising is pretty much perfect:
It's already a pure pleasure just to watch you develop... can hardly imagine how it will be working with...
Truly amazing work! 8-)
Dade wrote: Tue Apr 17, 2018 4:37 pm It can really work well, this is a 100spp rendering and the denoising is pretty much perfect
I'm also positively surprised, it works much better than I hoped for.
Asticles
Post by Asticles »
Is there any word bigger than awesome?
Cannot wait to have this! This could make bidirectional to be the weapon of choice for everyone.
Congrats.
