system hangs when GPU rendering material
Dez!
Post by Dez! »
https://dropmefiles.com/7rg4b
when rendering this stuff on the GPU my computer freezes.
I cannot finish the project because of this.
Re: system hangs when GPU rendering material
You mean the whole OS becomes unresponsive? Can you describe it in more detail?
This usually hints to a problem in the GPU driver or OS itself. A mere user-executed program like LuxCore doesn't have the power to freeze the whole OS. You could try to update your drivers.
Looks fine on my side, using latest BLC 2.5b1 on B 2.91
Dez!
Post by Dez! »
The problem was hidden in the AMDGPU-PRO Linux driver.
I couldn't make it work by any effort.
On Windows, the AMD driver completed the task without error.
Thank you all for your participation
Dez!
Post by Dez! »
The adventure continues. I can't handle the question.
If there is Band in the material at the Bump input, then various artifacts occur. For example, when rendering with tiles:
https://prnt.sc/w2niv7
Here is an example artifact file: https://dropmefiles.com/urSRR
I have tried all drivers on Windows and Linux.
Could it be my graphics card? Or does this happen on all AMD video cards?
Dez! wrote: Mon Dec 14, 2020 6:59 pm Could it be my graphics card? Or does this happen on all AMD video cards?
Yes, it is an AMD-only problem: https://github.com/LuxCoreRender/BlendL ... issues/593
Dez!
Post by Dez! »
Thank you for your reply.
I reconfigured the materials and everything works great now.
