HoppyHopp
Posts: 35 Joined: Thu Aug 27, 2020 6:27 pm
Post
by HoppyHopp » Mon Sep 21, 2020 8:03 pm
Hey,
i played arround mixing a normal and bump map. When i use "Add" there is a big difference between CPU and GPU.
It is the same with "Subtract" but no problem when i use "Mix", "Multiplay" or "Divide"
CPU
GPU
Nodes
Posts: 5675 Joined: Mon Dec 04, 2017 8:36 pm
Post
by Dade » Mon Sep 21, 2020 10:19 pm
What Lux version are you using ? Can you post a simple test scene with a cube and your material definition ?
HoppyHopp
Post
by HoppyHopp » Thu Oct 08, 2020 3:00 pm
Here i have another missmatch between CPU and GPU.
CPU
GPU
Nodes
I attached the blend-file
Lightbox1.blend
(2.08 MiB) Downloaded 439 times
HoppyHopp
Post
by HoppyHopp » Fri Oct 09, 2020 9:12 pm
I tried now 2.4 and latest 2.5 version. Still the sam difference between cpu and gpu.
Can someone reproduce the problem with my file and can solve the problem?
Dez!
Posts: 369 Joined: Sun Apr 08, 2018 1:09 am
Post
by Dez! » Mon Oct 19, 2020 9:01 am
my video driver breaks down.
the system goes into a black screen.
checked three times. only reset helped three times
Posts: 1083 Joined: Sun Jul 01, 2018 12:07 pm
Post
by FarbigeWelt » Tue Oct 20, 2020 4:31 pm
HoppyHopp
Post
by HoppyHopp » Wed Oct 21, 2020 9:29 am
FarbigeWelt wrote: Tue Oct 20, 2020 4:31 pm
Similar result like yours.
So how do we fix it? I mean there shouldn't be a difference, right?
Post
by FarbigeWelt » Wed Oct 21, 2020 3:42 pm
HoppyHopp wrote: Wed Oct 21, 2020 9:29 am
... I mean there shouldn't be a difference, right?
Correct. Some one should open an Issue in Github.
