								HoppyHopp
		Posts:  35 Joined:  Thu Aug 27, 2020 6:27 pm
						Post
								by HoppyHopp  Mon Sep 21, 2020 8:03 pm
			Hey,
i played arround mixing a normal and bump map. When i use "Add" there is a big difference between CPU and GPU.
It is the same with "Subtract" but no problem when i use "Mix", "Multiplay" or "Divide"
 CPU
GPU
Nodes
		Posts:  5675 Joined:  Mon Dec 04, 2017 8:36 pmLocation:  Italy
						Post
								by Dade  Mon Sep 21, 2020 10:19 pm
			What Lux version are you using ? Can you post a simple test scene with a cube and your material definition ?
								HoppyHopp
						Post
								by HoppyHopp  Thu Oct 08, 2020 3:00 pm
			Here i have another missmatch between CPU and GPU.
CPU
GPU
Nodes
I attached the blend-file
			Lightbox1.blend (2.08 MiB) Downloaded 316 times
								HoppyHopp
						Post
								by HoppyHopp  Fri Oct 09, 2020 9:12 pm
			I tried now 2.4 and latest 2.5 version. Still the sam difference between cpu and gpu.
Can someone reproduce the problem with my file and can solve the problem?
								Dez!
		Posts:  369 Joined:  Sun Apr 08, 2018 1:09 amLocation:  Ekaterinburg
						Post
								by Dez!  Mon Oct 19, 2020 9:01 am
			my video driver breaks down.
		Posts:  1083 Joined:  Sun Jul 01, 2018 12:07 pmLocation:  Switzerland
						Post
								by FarbigeWelt  Tue Oct 20, 2020 4:31 pm
								HoppyHopp
						Post
								by HoppyHopp  Wed Oct 21, 2020 9:29 am
			FarbigeWelt  wrote: Tue Oct 20, 2020 4:31 pm
Similar result like yours.
So how do we fix it? I mean there shouldn't be a difference, right?
						Post
								by FarbigeWelt  Wed Oct 21, 2020 3:42 pm
			HoppyHopp  wrote: Wed Oct 21, 2020 9:29 am FarbigeWelt  wrote: Tue Oct 20, 2020 4:31 pm
... I mean there shouldn't be a difference, right?
Correct. Some one should open an Issue in Github.
