Blender custom nodes can't be animated
Material nodes can't be animated. i'm trying to simulate a car brake + back light animation. any alternative ?
Re: BlendLuxCore Development
Sharlybg wrote: Sun May 03, 2020 4:31 pm Material nodes can't be animated. i'm trying to simulate a car brake + back light animation. any alternative ?
It would be good if someone could make a bug report about this in the Blender bug tracker, I'm not sure if the Blender devs know about this.
If you are comfortable with Python scripting, you can use a frame_change_pre handler as an alternative.
capture.mp4
(934.26 KiB) Downloaded 230 times
frame_change_script (1).blend
(691.7 KiB) Downloaded 264 times
Thanks for the help but learn to do it by scripting currently is way too much for the time i have to spent on the animation.
i hope to have correctly done it in the right place :roll:
https://developer.blender.org/T76381
You could also try to replicate your node setup with Cycles nodes, where keyframes work.
B.Y.O.B. wrote: Sun May 03, 2020 9:20 pm You could also try to replicate your node setup with Cycles nodes, where keyframes work.
Yes thanks you will go this road finally. another strenght of blendluxcore ability to read in competitor **mind** :mrgreen:
Well done BYOB :idea:
Well done BYOB
Heu maybe i will change. because in the mean time this happen.
No issue here using 2.90 (sub 0), branch: master, commit date: 2020-05-01 20:41, hash: rB06839379c5d4 or
2.83 (sub 15), branch: master, commit date: 2020-05-01 21:42, hash: rBbba11c68c404
Please try the latest daily build: https://builder.blender.org/download/
If the problem persists, please let us know so we can re-open the report. Don't forget to mention the specific version you tested again.
But the less invasive way will be to use 2.82a with cycles node. ;) . As the fix work in 2.83 and 2.90 i should avoid additional instability with unofficial build.
Sharlybg wrote: Mon May 04, 2020 11:16 am As the fix work in 2.83
It's in 2.83? That's great to hear.
tested with 2.83. it work in final render but not in viewport (i mean hiting spacebar "animation play" don't update). and also it doesn't display keyframe in timeline.
