Pretty cool!
anisotropic metal UV problem
Re: anisotropic metal UV problem
Nice render indeed!lacilaci wrote: Fri Feb 01, 2019 6:36 pm Nice.
Looks like an interesting scene by the way, will you show it once it's finished?
Pretty cool!
Though I think lacilaci may add to this box a big GI Caching On and Ditch BCD Denoiser switch.....
Oh yes, a big red button "kill BCD"
lighting_freak
Thanks for helping me. I've additionally added a normal texture to emphasis the polishing direction.
BR
stupid me, it was really simply the position of the lightsource and the orientation of the disc.It's might be light falling at different angle.
Moved lamp a bit to the right:
BR
OS - Windows 7 X64
CPU - Intel CORE i7
CPU - Intel CORE i7
steveernst117
Hey, so I'm having the same issue on an only slightly-modified default cylinder (with the strange face artifacting happening). I see you 'fixed the mesh', but my mesh doesn't have anything to fix, really, so could you please go into a bit more detail on how you got rid of that?
steveernst117
Okay, well for anyone having issues in the future, it turns out you need lots of geo to avoid the faceted look, and to solve the inevitable pinching effect you're going to get with subsurf, make a containment loop around the center loop, then shrink them both waaaay down so the pinching isn't as visible. That should get you there.
