Is it possible to do something like this in Lux: https://www.youtube.com/watch?v=-VgtSL5 ... e=youtu.be
Many thanks
Repeating Textures
Re: Repeating Textures
There are many techniques in that video, it would be good if you could show the Cycles node tree of a specific one so we can translate that to Lux, if viable.
A simple trick is something like this: viewtopic.php?f=4&t=102&p=1855#p1902
However the effectiveness is a bit limited (depends on your scene).
@BYOB
Thank you for the simple trick link.
I've downloaded the Polygon Node and under the hood is looks very complicated so I'll see how far I can get converting it to Lux.
https://www.dropbox.com/s/hn30svmf2s6at ... blend?dl=0
![Confused :?](./images/smilies/icon_e_confused.gif)
Side note: the correct solution to this problem is writing https://eheitzresearch.wordpress.com/722-2/ for Lux.
@DADE Thank you for the information.
Is it possible to add noise to a vector, like in the attached image (Cycles)?
Thank you
Thank you
Currently not, but it's something I'd like to have eventually.
@BYOB
ok, Thank you.
ok, Thank you.
