the dif is more noticeable in the part lit by the sun.The 64 version lit part become slightly yellow. Normally render become brighter with higher bounces
Bidir darkening
Bidir darkening
During testing i just found that Bidir engine start darkening with higher bounce value. Here is a test with 10 vs 64 max bounces eye/light path. side by side :
Re: Bidir darkening
Yes with same setting.
Re: Bidir darkening
Finally got time to test sobol : and the answer is NO. sobol look unchanged no matter the max bounce.
max 20
max 64
