Bidir darkening
Bidir darkening
During testing i just found that Bidir engine start darkening with higher bounce value. Here is a test with 10 vs 64 max bounces eye/light path. side by side :
the dif is more noticeable in the part lit by the sun.The 64 version lit part become slightly yellow. Normally render become brighter with higher bounces :?
Fox
Re: Bidir darkening
Post by Fox »
Is this MLT?
Re: Bidir darkening
Fox wrote: Sat Feb 29, 2020 1:42 amIs this MLT?
Yes with same setting.
Re: Bidir darkening
Does it happens with Sobol ?
Re: Bidir darkening
Dade wrote: Sat Feb 29, 2020 2:02 pm Does it happens with Sobol ?
Finally got time to test sobol : and the answer is NO. sobol look unchanged no matter the max bounce.
max 20
max 64
