Should the triplanar mapping be exported with local mapping or all textures? The imagemap texture node export uvmapping2d as default mapping.
I'm confused cause here https://github.com/LuxCoreRender/BlendLuxCore/pull/320 in the first screenshot alpistihno shows nodes from 2d mapping and in his render it worked... But then again, this should not use uv's.
By the way all the objects I tried had their origins at their centers.
I can confirm that there is something wrong with the triplanar mapping. If I use default color input it renders correctly but if I use local mapping it doesn't. If I use same uv index it renders not correctly, too. With different uv index (but same copied uv map) it renders correctly.
When I use standard colors it renders correctly but with images it does not.
#triplanar with color
scene.textures.1866357581976Color.type = "triplanar"
scene.textures.1866357581976Color.texture1 = 1 0 0
scene.textures.1866357581976Color.texture2 = 0 0 1
scene.textures.1866357581976Color.texture3 = 0 1 0
scene.textures.1866357581976Color.mapping = "globalmapping3d"
scene.textures.1866357581976Color.mapping.transformation = 1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1
# image with uv map
scene.textures.1866357603800Color.type = "imagemap"
scene.textures.1866357603800Color.file = "F:\Users\Michael\AppData\Local\Temp\tmp4hm448oa.png"
scene.textures.1866357603800Color.wrap = "repeat"
scene.textures.1866357603800Color.mapping.type = "uvmapping2d"
scene.textures.1866357603800Color.mapping.uvscale = 0.5 -0.5
scene.textures.1866357603800Color.mapping.uvindex = 0
scene.textures.1866357603800Color.mapping.rotation = 0
scene.textures.1866357603800Color.mapping.uvdelta = 0 2
scene.textures.1866357603800Color.channel = "default"
scene.textures.1866357603800Color.gamma = 2.2000000476837158
scene.textures.1866357603800Color.gain = 1
# triplanar with local mapping
scene.textures.1866357602808Color.type = "imagemap"
scene.textures.1866357602808Color.file = "F:\Users\Michael\AppData\Local\Temp\tmp4hm448oa.png"
scene.textures.1866357602808Color.wrap = "repeat"
scene.textures.1866357602808Color.mapping.type = "uvmapping2d"
scene.textures.1866357602808Color.mapping.uvscale = 0.5 -0.5
scene.textures.1866357602808Color.mapping.uvindex = 0
scene.textures.1866357602808Color.mapping.rotation = 0
scene.textures.1866357602808Color.mapping.uvdelta = 0 2
scene.textures.1866357602808Color.channel = "default"
scene.textures.1866357602808Color.gamma = 2.2000000476837158
scene.textures.1866357602808Color.gain = 1
scene.textures.1866357604792Color.type = "triplanar"
scene.textures.1866357604792Color.texture1 = "1866357602808Color"
scene.textures.1866357604792Color.texture2 = "1866357602808Color"
scene.textures.1866357604792Color.texture3 = "1866357602808Color"
scene.textures.1866357604792Color.mapping = "localmapping3d"
scene.textures.1866357604792Color.mapping.transformation = 1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1
# triplanar with same uv map
scene.textures.1866357596360Color.type = "imagemap"
scene.textures.1866357596360Color.file = "F:\Users\Michael\AppData\Local\Temp\tmp4hm448oa.png"
scene.textures.1866357596360Color.wrap = "repeat"
scene.textures.1866357596360Color.mapping.type = "uvmapping2d"
scene.textures.1866357596360Color.mapping.uvscale = 0.5 -0.5
scene.textures.1866357596360Color.mapping.uvindex = 0
scene.textures.1866357596360Color.mapping.rotation = 0
scene.textures.1866357596360Color.mapping.uvdelta = 0 2
scene.textures.1866357596360Color.channel = "default"
scene.textures.1866357596360Color.gamma = 2.2000000476837158
scene.textures.1866357596360Color.gain = 1
scene.textures.1866357582968Color.type = "triplanar"
scene.textures.1866357582968Color.texture1 = "1866357596360Color"
scene.textures.1866357582968Color.texture2 = "1866357596360Color"
scene.textures.1866357582968Color.texture3 = "1866357596360Color"
scene.textures.1866357582968Color.mapping = "uvmapping3d"
scene.textures.1866357582968Color.mapping.transformation = 1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1
scene.textures.1866357582968Color.mapping.uvindex = 0
# triplanar with different uv map
scene.textures.1866988283512Color.type = "imagemap"
scene.textures.1866988283512Color.file = "F:\Users\Michael\AppData\Local\Temp\tmp4hm448oa.png"
scene.textures.1866988283512Color.wrap = "repeat"
scene.textures.1866988283512Color.mapping.type = "uvmapping2d"
scene.textures.1866988283512Color.mapping.uvscale = 0.5 -0.5
scene.textures.1866988283512Color.mapping.uvindex = 0
scene.textures.1866988283512Color.mapping.rotation = 0
scene.textures.1866988283512Color.mapping.uvdelta = 0 2
scene.textures.1866988283512Color.channel = "default"
scene.textures.1866988283512Color.gamma = 2.2000000476837158
scene.textures.1866988283512Color.gain = 1
scene.textures.1866988282520Color.type = "triplanar"
scene.textures.1866988282520Color.texture1 = "1866988283512Color"
scene.textures.1866988282520Color.texture2 = "1866988283512Color"
scene.textures.1866988282520Color.texture3 = "1866988283512Color"
scene.textures.1866988282520Color.mapping = "uvmapping3d"
scene.textures.1866988282520Color.mapping.transformation = 1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1
scene.textures.1866988282520Color.mapping.uvindex = 1- Attachments
- triplanar.blend
- (1.62 MiB) Downloaded 801 times
Good, hope this get's solved and we can start using uv-less objects easily.
By the way, is this a good base for stochastic/random texturing like here in fstorm:
tiles: randomized(with locked rotation so pattern is straight): or is this unrelated feature?
I have reworked a bit triplanar texture code and now it works as I expect:
The texture takes a new parameters (".uvindex") to select the UV channel to set (usually 0) and the mapping type should always be "localmapping3d" (the other don't make very much sense):
@Neo, can you merge the pull request, add the support for new ".uvindex" parameter and hard code the "localmapping3d" mapping type ? I don't think it is worth exposing that parameter.
scene.textures.tex.type = triplanar
scene.textures.tex.texture1 = tex1
scene.textures.tex.texture2 = tex2
scene.textures.tex.texture3 = tex3
scene.textures.tex.uvindex = 0
scene.textures.tex.mapping.type = localmapping3d
It is not related to triplanar mapping but it can be implemented as a special type of mapping
Thanks. Can't wait to get my hands on this..Dade wrote: Sat Jan 04, 2020 1:34 pm I have reworked a bit triplanar texture code and now it works as I expect:
@Neo, can you merge the pull request, add the support for new ".uvindex" parameter and hard code the "localmapping3d" mapping type ? I don't think it is worth exposing that parameter.Code: Select all
scene.textures.tex.type = triplanar scene.textures.tex.texture1 = tex1 scene.textures.tex.texture2 = tex2 scene.textures.tex.texture3 = tex3 scene.textures.tex.uvindex = 0 scene.textures.tex.mapping.type = localmapping3d
- alpistinho
- Developer
Thanks for the help!Dade wrote: Sat Jan 04, 2020 1:34 pm I have reworked a bit triplanar texture code and now it works as I expect
Thanks Dade for reworking. There is still something strange. With local mapping it shouldn't matter how the object is transformed but if you rotate the object then the texture gets distorted. Is the hitpoint position or normal evaluated in local or global coordinate frame?
I think it may be a problem with the normal not being transformed (only the point is), I will check.neo2068 wrote: Sat Jan 04, 2020 4:13 pm Is the hitpoint position or normal evaluated in local or global coordinate frame?
