I'd like to create a living room type fire (and smoke)
I can do it in Cycles, but can't work out how to do it correctly in Lux.
Could someone please upload a basic node setup or scene for me to learn from?
Many thanks
						Volumes for Fire and Smoke
- FarbigeWelt
 - Contact:
Re: Volumes for Fire and Smoke
Did you read and follow B.Y.O.B‘s post already?Racleborg wrote: Wed Aug 28, 2019 8:23 pm I'd like to create a living room type fire (and smoke)
Many thanks
No, I hadn't seen that.Did you read and follow B.Y.O.B‘s post already?
That's great and very helpful.
Thank you
.........so, if the Emitter is setup for FIRE + SMOKE can I separate these two in the SMOKE DATA node as it only gives option for FIRE, HEAT, COLOR, DENSITY and VELOCITY? or do I need to do something else?
Thanks
						Thanks
Oops, sorry for wasting time
  When both fire and smoke is selected the colour is different for each. (I'm fairly sure that's correct)
There is a node tree preset for "Fire and Smoke" available in the material properties, apply it to the domain material to have a starting point.
Thanks. Found it!
 I wasn't looking in the right place. Like the Disney Shader I think?
It's not where I normally add materials from. (I don't know the name of all the UI areas so I've attached an image.
The missing disney has been fixed.
Thank you
