Volumes for Fire and Smoke
Racleborg
Post by Racleborg »
I'd like to create a living room type fire (and smoke)
I can do it in Cycles, but can't work out how to do it correctly in Lux.
Could someone please upload a basic node setup or scene for me to learn from?
Many thanks
Re: Volumes for Fire and Smoke
Post by FarbigeWelt »
Racleborg wrote: Wed Aug 28, 2019 8:23 pm I'd like to create a living room type fire (and smoke)
Many thanks
Did you read and follow B.Y.O.B‘s post already?
Racleborg
Post by Racleborg »
No, I hadn't seen that.
That's great and very helpful.
Thank you
Racleborg
Post by Racleborg »
.........so, if the Emitter is setup for FIRE + SMOKE can I separate these two in the SMOKE DATA node as it only gives option for FIRE, HEAT, COLOR, DENSITY and VELOCITY? or do I need to do something else?
Thanks
Racleborg
Post by Racleborg »
Oops, sorry for wasting time :oops: When both fire and smoke is selected the colour is different for each. (I'm fairly sure that's correct)
There is a node tree preset for "Fire and Smoke" available in the material properties, apply it to the domain material to have a starting point.
Racleborg
Post by Racleborg »
Thanks. Found it! :) :) :) I wasn't looking in the right place. Like the Disney Shader I think?
It's not where I normally add materials from. (I don't know the name of all the UI areas so I've attached an image.
The missing disney has been fixed.
Racleborg
Post by Racleborg »
Thank you
