Filesaver blender blend texture transformation
Posted: Mon Dec 17, 2018 4:15 pm
by Fox
Can it be the filesaver engine blender blend texture transformation is wrong?
I can't read 4x4 matrix, is it correct?
LuxCore render looks wrong / different.
Blender
Translate X0 Y1.19 Z0
Rotate X90 Y0 Z0
Scale uniform 17.05
Filesaver
17.0460033 0 0 0 0 1.2869375e-06 17.0460033 0 0 -17.0460033 1.2869375e-06 0 0 1.19400001 0 1
Re: Filesaver blender blend texture transformation
Posted: Mon Dec 17, 2018 4:40 pm
Are you using v2.0 or the latest v2.1beta?
There is a bug when using local transformations in v2.0 which is fixed in v2.1.
Posted: Mon Dec 17, 2018 4:50 pm
by Fox
I have 2.1 beta 2, will update.
Posted: Mon Dec 17, 2018 5:02 pm
No beta2 should include that fix.
Can you upload a scene that shows the problem?
Posted: Mon Dec 17, 2018 5:10 pm
by Fox
2.1beta4 still broken
Z looks inverted
download/file.php?id=2848
Posted: Mon Dec 17, 2018 5:43 pm
I can reproduce it.
Posted: Mon Dec 17, 2018 5:45 pm
by Fox
Better sample
In LuxCore from filesaver
Better sample.zip
(189.74 KiB) Downloaded 293 times
Posted: Tue Dec 18, 2018 3:49 am
by Fox
Issue is solved for me.
Don't know how, but the global scale was easy to tune to the looks of object scale, this i was not able to do yesterday.
Posted: Thu Dec 20, 2018 9:54 am
But is there a bug should I check :?:
Posted: Thu Dec 20, 2018 10:42 am
Yes, there's definitely a bug, but I'm not sure if it's in the addon or in the filesaver engine.
