Filesaver blender blend texture transformation
Fox
Post by Fox »
Can it be the filesaver engine blender blend texture transformation is wrong?
I can't read 4x4 matrix, is it correct?
LuxCore render looks wrong / different.
Blender
Translate X0 Y1.19 Z0
Rotate X90 Y0 Z0
Scale uniform 17.05
Filesaver
17.0460033 0 0 0 0 1.2869375e-06 17.0460033 0 0 -17.0460033 1.2869375e-06 0 0 1.19400001 0 1
Re: Filesaver blender blend texture transformation
Are you using v2.0 or the latest v2.1beta?
There is a bug when using local transformations in v2.0 which is fixed in v2.1.
Fox
Post by Fox »
I have 2.1 beta 2, will update.
No beta2 should include that fix.
Can you upload a scene that shows the problem?
Fox
Post by Fox »
2.1beta4 still broken
Z looks inverted
download/file.php?id=2848
I can reproduce it.
laser_milkwater_byob.blend
.blend file
(336.98 KiB) Downloaded 268 times
Blender
Blender
Filesaver Output
Filesaver Output
laser_milkwater_byob_LuxCore.zip
.cfg/.scn
(17.28 KiB) Downloaded 251 times
Fox
Post by Fox »
Better sample
In LuxCore from filesaver
Better sample.zip
(189.74 KiB) Downloaded 293 times
Fox
Post by Fox »
Issue is solved for me.
Don't know how, but the global scale was easy to tune to the looks of object scale, this i was not able to do yesterday.
But is there a bug should I check :?:
Yes, there's definitely a bug, but I'm not sure if it's in the addon or in the filesaver engine.
