Page 1 of 3
Crash with OpenCL
Posted: Tue Jan 30, 2018 7:53 pm
by david57
Blender is still crashing on me.
I just now checked to see if error messages in the terminal but there are none while the file is loaded.
I noticed when I clicked the render button it started to write info on the System Console but I could not read it out.
I was to fast and then it crashed.
Re: Windows: Can't enable addon in latest Blender
Posted: Tue Jan 30, 2018 8:39 pm
by neo2068
Could you start blender from command line?
You can open a command line interface with WINDOWS KEY + R and then type "cmd" and hit enter.
In the Terminal window you could switch to the installation folder of blender , e.g. "C:\Program Files\Blender Foundation\Blender", and start with "blender.exe". When blender crashes then, the terminal window should stay open and you could post the output before the crash.
Posted: Tue Jan 30, 2018 9:13 pm
by david57
Thanks, that worked.
Here is the print out:
Posted: Tue Jan 30, 2018 9:38 pm
david57 wrote: Tue Jan 30, 2018 9:13 pm Thanks, that worked.
Try to use only the OpenCL CPU device and check if it still crash :?:
Posted: Tue Jan 30, 2018 9:46 pm
by david57
The CPU Path works fine and Bidirectional also works fine.
Posted: Tue Jan 30, 2018 9:49 pm
david57 wrote: Tue Jan 30, 2018 9:46 pm The CPU Path works fine and Bidirectional also works fine.
To be sure, I'm not talking of PATHCPU but of PATHOCL with the AMD OpenCL CPU device, does it work ? You may want also try to run a test with a single GPU to check if the problem is related to the usage of 2 GPUs.
If you have a test scene that always crashes for you and you can post, I can try if here it works.
Re: Crash with OpenCL
Posted: Tue Jan 30, 2018 9:51 pm
Moved the posts to a dedicated thread.
Posted: Tue Jan 30, 2018 9:57 pm
by david57
Ok, having trouble understanding about PATHCPU and PATHOCL. What do they mean?
My CPU is an Intel i7-6700K CPU@ 4.00GHz and not an AMD.
Posted: Tue Jan 30, 2018 10:02 pm
by david57
Ok, here is the test blender file:
Posted: Tue Jan 30, 2018 10:09 pm
by david57
Unable to use just one GPU. How do I use just one of them?
