Blender is still crashing on me.
I just now checked to see if error messages in the terminal but there are none while the file is loaded.
I noticed when I clicked the render button it started to write info on the System Console but I could not read it out.
I was to fast and then it crashed.
Crash with OpenCL
Re: Windows: Can't enable addon in latest Blender
Could you start blender from command line?
You can open a command line interface with WINDOWS KEY + R and then type "cmd" and hit enter.
In the Terminal window you could switch to the installation folder of blender , e.g. "C:\Program Files\Blender Foundation\Blender", and start with "blender.exe". When blender crashes then, the terminal window should stay open and you could post the output before the crash.
Thanks, that worked.
Here is the print out:
Try to use only the OpenCL CPU device and check if it still crash
The CPU Path works fine and Bidirectional also works fine.
To be sure, I'm not talking of PATHCPU but of PATHOCL with the AMD OpenCL CPU device, does it work ? You may want also try to run a test with a single GPU to check if the problem is related to the usage of 2 GPUs.
If you have a test scene that always crashes for you and you can post, I can try if here it works.
Re: Crash with OpenCL
Ok, having trouble understanding about PATHCPU and PATHOCL. What do they mean?
My CPU is an Intel i7-6700K CPU@ 4.00GHz and not an AMD.
Ok, here is the test blender file:
- Attachments
- GELAS_luxcorev2.blend
- (1.09 MiB) Downloaded 378 times
Unable to use just one GPU. How do I use just one of them?
