Page 1 of 3
Azure pipeline building, tasting and releasing
Posted: Mon Oct 15, 2018 3:39 pm
GitHub has recently been acquired by Microsoft and they are now offering a free and
unlimited (for open source) building, testing and releasing pipeline on Azure (the MS cloud service).
This is a big step forward compared Trevis-CI where there is a one hour limit on the process time so I'm not even able to get a full build (i.e. I have to upload some pre-built library).
This is can potentially lead some major improvement:
- automatic full compilation after any commit of OpenCL and not OpenCL version for Windows, Linux and MacOS;
- automatic running all unit tests for all versions mentioned above (this can easily take days);
- automatic release of executables for all versions mentioned above (aka daily builds);
I'm currently developing this solution at
https://dev.azure.com/LuxCoreRender/LuxCoreRender and I have a working version of the automatic compilation/test/upload of No-OpenCL version for Linux.
For Developers: if you give me your Microsoft username, I can add you to the project.
Re: Azure pipeline building, tasting and releasing
Posted: Mon Oct 15, 2018 4:09 pm
Dade wrote: Mon Oct 15, 2018 3:39 pm
Who wants to add an "automatically update to latest daily build" feature to BlendLuxCore?
For people who want the latest bugs and features.
Posted: Mon Oct 15, 2018 5:51 pm
So can we have daily builds for blender??
Posted: Mon Oct 15, 2018 6:53 pm
lacilaci wrote: Mon Oct 15, 2018 5:51 pm
That is the idea (in the long term).
P.S. Indeed, I discovered that claimed "unlimited run time" is limited to 60 minutes by default (!!!) however I should have found a setting to have a 360 minutes limit, testing right now.
Posted: Tue Oct 16, 2018 3:38 pm
Dade wrote: Mon Oct 15, 2018 6:53 pm
It works and 360 mins is something I can work with.
BTW, daily builds will be available here:
https://github.com/LuxCoreRender/LuxCor ... tag/latest
It is a a release automatically created by Azure pipeline.
Posted: Fri Oct 19, 2018 8:07 pm
Now
https://github.com/LuxCoreRender/LuxCor ... tag/latest includes both the Linux OpenCL-less and OpenCL version of the daily build.
Posted: Tue Oct 23, 2018 9:43 am
@Acasta69: I have moved OS specific scripts from scripts/azurepipeline to scripts/azurepipeline/linux and scripts/azurepipeline/windows directories.
Posted: Tue Oct 23, 2018 2:39 pm
by acasta69
The first automated Windows build (no openCL) seems to have succeeded.
However I am a bit unsure about how to get the resulting package here:
@Dade: when I am at this stage:
I've never seen this before so I am unsure about how to proceed with authorizations.
Is it ok to use OAuth with my GitHub account? Or is this something better done by you using different authorizations?
Posted: Tue Oct 23, 2018 3:40 pm
acasta69 wrote: Tue Oct 23, 2018 2:39 pm
I upload the built files trough a specific Azure pipeline plugin, it is under "Releases => Edit Pipeline", click on "Release to GitHub/1 job, 3 tasks". I have added one more task to upload the windows build and queued a new build. Let's see if it works.
All this stuff is totally undocumented and we have to proceed blindly and with trial and errors
Posted: Tue Oct 23, 2018 6:18 pm
Dade wrote: Tue Oct 23, 2018 3:40 pm
It looks like it worked. The .zip is no on
The only thing missing seems the pyluxcoretools.exe created by the create-standalone.bat with PyInstaller
