GitHub has recently been acquired by Microsoft and they are now offering a free and unlimited (for open source) building, testing and releasing pipeline on Azure (the MS cloud service).
This is a big step forward compared Trevis-CI where there is a one hour limit on the process time so I'm not even able to get a full build (i.e. I have to upload some pre-built library).
This is can potentially lead some major improvement:
- automatic full compilation after any commit of OpenCL and not OpenCL version for Windows, Linux and MacOS;
- automatic running all unit tests for all versions mentioned above (this can easily take days);
- automatic release of executables for all versions mentioned above (aka daily builds);
I'm currently developing this solution at https://dev.azure.com/LuxCoreRender/LuxCoreRender and I have a working version of the automatic compilation/test/upload of No-OpenCL version for Linux.
For Developers: if you give me your Microsoft username, I can add you to the project.
Azure pipeline building, tasting and releasing
Re: Azure pipeline building, tasting and releasing
Who wants to add an "automatically update to latest daily build" feature to BlendLuxCore?Dade wrote: Mon Oct 15, 2018 3:39 pm - automatic release of executables for all versions mentioned above (aka daily builds);
For people who want the latest bugs and features.
So can we have daily builds for blender??
That is the idea (in the long term).
P.S. Indeed, I discovered that claimed "unlimited run time" is limited to 60 minutes by default (!!!) however I should have found a setting to have a 360 minutes limit, testing right now.
It works and 360 mins is something I can work with.Dade wrote: Mon Oct 15, 2018 6:53 pm P.S. Indeed, I discovered that claimed "unlimited run time" is limited to 60 minutes by default (!!!) however I should have found a setting to have a 360 minutes limit, testing right now.
BTW, daily builds will be available here: https://github.com/LuxCoreRender/LuxCor ... tag/latest
It is a a release automatically created by Azure pipeline.
Now https://github.com/LuxCoreRender/LuxCor ... tag/latest includes both the Linux OpenCL-less and OpenCL version of the daily build.
@Acasta69: I have moved OS specific scripts from scripts/azurepipeline to scripts/azurepipeline/linux and scripts/azurepipeline/windows directories.
The first automated Windows build (no openCL) seems to have succeeded.
However I am a bit unsure about how to get the resulting package here:
@Dade: when I am at this stage: I've never seen this before so I am unsure about how to proceed with authorizations.
Is it ok to use OAuth with my GitHub account? Or is this something better done by you using different authorizations?
I upload the built files trough a specific Azure pipeline plugin, it is under "Releases => Edit Pipeline", click on "Release to GitHub/1 job, 3 tasks". I have added one more task to upload the windows build and queued a new build. Let's see if it works.acasta69 wrote: Tue Oct 23, 2018 2:39 pm The first automated Windows build (no openCL) seems to have succeeded.
All this stuff is totally undocumented and we have to proceed blindly and with trial and errors
It looks like it worked. The .zip is no on https://github.com/LuxCoreRender/LuxCor ... tag/latestDade wrote: Tue Oct 23, 2018 3:40 pm I upload the built files trough a specific Azure pipeline plugin, it is under "Releases => Edit Pipeline", click on "Release to GitHub/1 job, 3 tasks". I have added one more task to upload the windows build and queued a new build. Let's see if it works.
The only thing missing seems the pyluxcoretools.exe created by the create-standalone.bat with PyInstaller
