Build LuxCore with Python version 3.6
Hello all,
I followed this guide:
https://github.com/LuxCoreRender/WindowsCompile
And I want to build with python version 3.6 (I also have blender version with 3.6 python https://github.com/TylerGubala/blenderpy)
What should I change to make it work?
Re: Build LuxCore with Python version 3.6
You can build luxcore with Python 3.6 with this command:
I have tested the resulting pyluxcore with a blender buildbot build, I assume you are using one of those...
cmake-build-x64.bat /python36
That worked, but now I understand that I wanted to build it as a addon for blender (blendluxcore?) Can it be done?
Clone BlendLuxCore repo, then run get_binaries.py.
See the readme here for more information:
https://github.com/LuxCoreRender/BlendL ... master/bin
After that, you can copy or symlink the BlendLuxCore repo to your Blender addons directory (or zip it and install via user preferences).
pyluxcoretool.exe is missing, what could be the problem?
Missing PyInstaller when building LuxCore
Hoped it was it but no, pyinstaller is installed and working:
The build had some warnings I don't know if they are related
Could I generate it manually perhaps? What is the pyinstaller command?
Maybe you are missing PySide?
Anyway, BlendLuxCore works without pyluxcoretools as well, they are only needed for network rendering.
If you need pyluxcoretools.exe, you can generate it after the build is completed with this command:
You will then find a folder named "luxcorerender" containing all required files, including that one.
create-standalone.bat
Hi, if I understand this correctly Blender dev´s upgrade to Python 3.7.
Because you´re at it may change to 3.7 too.
Cheers, mib
https://developer.blender.org/rB51ac494 ... 61d6ba3ad9
Cheers, mib
