Spot light with image as a pattern
Posted: Wed Sep 05, 2018 9:42 am
by DorPrz
Hello,
I am trying to render simple scene with spot light with image as a pattern.
The results does not show the pattern at all, what could be the problem?
Settings:
Results:
Pattern:
Re: Spot light with image as a pattern
Posted: Wed Sep 05, 2018 10:34 am
I'm not sure if .bmp is a supported format. LuxCore has projection lights (but not spot light with a texture image), I assume BlendLuxCore may switch automatically the light type. Can you post the test scene ?
Posted: Wed Sep 05, 2018 10:44 am
by DorPrz
I know for sure this .bmp map worked in older version of luxrender (1.x)
I couldn't attach the .bmp file so I uploaded it to here:
https://ufile.io/kjhta
untitled.blend
(545.53 KiB) Downloaded 946 times
Posted: Wed Sep 05, 2018 6:45 pm
.bmp works and yes, the projector light source is automatically used if an image is set.
Your light source is just not bright enough.
If I set the gain to 40000, it is visible.
Posted: Thu Sep 06, 2018 12:53 pm
by DorPrz
I encounter very strange phenomena.
Sometimes the projector isn't texture correctly (about 10% of the time)
2 consecutive renders with the same settings may yield different results:
Could be a bug?
Posted: Thu Sep 06, 2018 1:23 pm
Please upload a .blend file that shows the issue, with steps how to reproduce it.
Posted: Thu Sep 06, 2018 1:47 pm
by DorPrz
Attached the scene the texture is the same as what I uploaded few comments above.
run in the python console:
for i in range(100):
	bpy.data.scenes['Scene'].render.filepath = r'C:\Users\dorp\Desktop\blenderGPU\tests\{}'.format(i)
	bpy.ops.render.render(write_still=True)
Change the path to somewhere else in your pc
Posted: Thu Sep 06, 2018 2:02 pm
by DorPrz
I changed the time limit to 10 seconds to reproduce this faster (uploaded again)
And on the 4th render I got the same issue:
Posted: Thu Sep 06, 2018 2:21 pm
Currently rendering the sequence.
By the way, I don't know what you aim for, but I could increase the rendering performance significantly by switching off the sky light in the world settings, and limiting path depth to 1.
Also: I assume you render on a GPU?
Can you try if this also happens if you only render on the CPU?
Posted: Thu Sep 06, 2018 2:33 pm
by DorPrz
Yes, I did render it on a GTX 1060 6GB
I will try on a cpu and report results
