Spot light with image as a pattern
DorPrz
Post by DorPrz »
Hello,
I am trying to render simple scene with spot light with image as a pattern.
The results does not show the pattern at all, what could be the problem?
Settings:
Results:
Pattern:
Re: Spot light with image as a pattern
I'm not sure if .bmp is a supported format. LuxCore has projection lights (but not spot light with a texture image), I assume BlendLuxCore may switch automatically the light type. Can you post the test scene ?
DorPrz
Post by DorPrz »
I know for sure this .bmp map worked in older version of luxrender (1.x)
I couldn't attach the .bmp file so I uploaded it to here:
https://ufile.io/kjhta
untitled.blend
(545.53 KiB) Downloaded 692 times
.bmp works and yes, the projector light source is automatically used if an image is set.
Your light source is just not bright enough.
If I set the gain to 40000, it is visible.
DorPrz
Post by DorPrz »
I encounter very strange phenomena.
Sometimes the projector isn't texture correctly (about 10% of the time)
2 consecutive renders with the same settings may yield different results:
Could be a bug?
Please upload a .blend file that shows the issue, with steps how to reproduce it.
DorPrz
Post by DorPrz »
Attached the scene the texture is the same as what I uploaded few comments above.
run in the python console:
for i in range(100):
	bpy.data.scenes['Scene'].render.filepath = r'C:\Users\dorp\Desktop\blenderGPU\tests\{}'.format(i)
	bpy.ops.render.render(write_still=True)
Change the path to somewhere else in your pc
untitled.blend
(550.13 KiB) Downloaded 669 times
DorPrz
Post by DorPrz »
I changed the time limit to 10 seconds to reproduce this faster (uploaded again)
And on the 4th render I got the same issue:
untitled.blend
(550.13 KiB) Downloaded 653 times
Currently rendering the sequence.
By the way, I don't know what you aim for, but I could increase the rendering performance significantly by switching off the sky light in the world settings, and limiting path depth to 1.
Also: I assume you render on a GPU?
Can you try if this also happens if you only render on the CPU?
DorPrz
Post by DorPrz »
Yes, I did render it on a GTX 1060 6GB
I will try on a cpu and report results
