material and lightning setup advice needed
Posted: Thu May 12, 2022 12:36 pm
I try make corridor with doors.
When I use glossy shader I got this: There is noticeable difference in glossy on left door.
With Disney shader I got this: I don't understand why it is different in case of glossy shader. Sometimes use of glossy shader is enough but I don't mind use Disney instead. Is there situation when is better use one than the other?
For floor material, do you think it needs some tweaking? I somehow 'feel' more bump and maybe less glossy/roughness.
