Page 1 of 3
shadow color for glass issue
Posted: Sat Jan 01, 2022 4:54 pm
by nocivo
Hello,
I applied the shadow color white to the glass, but the ray that pass through the glass become more bright than where is not the glass.
please correct this issue.
I attach also the blender scene.
thanks
Re: shadow color for glass issue
Posted: Wed Jan 05, 2022 11:23 am
I should have fixed this problem. The next automatic build will include the fix.
Posted: Wed Jan 05, 2022 2:39 pm
by nocivo
thanks a lot for the fix. I will check soon.
Posted: Tue Apr 26, 2022 9:41 pm
by daros
Hi do you experience the same problem with shadow color?
bidir cpu - normal shadow color
this one is as expected by knowing the caustics-through glass problem
bidir cpu - white shadow color
should not cast shadow on the red object
PhotonGI on CPU glass normal shadow color
https://drive.google.com/file/d/1s02Zb8 ... sp=sharing
It increases the brightness of the area below the glass which is not expected.
\https://drive.google.com/file/d/1-vMFfh ... sp=sharing
tomorrow morning i post the scene
Posted: Wed Apr 27, 2022 9:03 am
Is the shadow color 100% white in both cases ?
Posted: Wed Apr 27, 2022 9:24 am
by daros
Hi sharlybg, it is full white in the second and in the fourth example. In the first and the third it is black.
by daros
Here is the luxcore scene
lightShadow.zip
(10.97 KiB) Downloaded 783 times
Posted: Thu Apr 28, 2022 1:20 am
Have you checked your geometry? Your issues stem from that mess. :shock:
A small advice.
Consistency. If you want your simulation to run as intended & physically correct, do your work in same manner - precise & concise , according to as IRL, or simply choose more forgiving, biased engine. ;)
Posted: Thu Apr 28, 2022 1:33 am
by daros
Hi kintux,
sorry i do not understand... what is wrong with this geometry? It's a very simple scene.
Below you find the obj.
Posted: Thu Apr 28, 2022 8:48 am
It's simple alright, and it's also reason why I'm shocked.
So, see what are " Overlapping polygons, Intersecting geometry, Walls w/o Thickness...
For further endeavors try and go by Forum rules described on top.
PS
"Testscene" in Blender format. Otherwise, who knows what's going on and it looks like even yourself have issues with basic fundamentals.
PPS.
Goes for your first scene and this latest .obj.
Just learn some from exemplary scenes...
https://luxcorerender.org/example-scenes/
