Blender not detecting AMD GPU
Posted: Sun Oct 31, 2021 7:27 pm
by kornflakekilla
It wont detect my GPU even though its under system preferences. I have rtx 570 4th gen and it doesn't show up under devices and when I set it to render under GPU it doesn't change and stays with the CPU.
Re: Blender not detecting AMD GPU
Posted: Sun Oct 31, 2021 8:11 pm
Try to run LuxMark, does it work ?
Posted: Sun Oct 31, 2021 9:29 pm
by kornflakekilla
Dade wrote: Sun Oct 31, 2021 8:11 pm Try to run LuxMark, does it work ?
This is what shows up
Posted: Sun Oct 31, 2021 9:30 pm
by kornflakekilla
Im on Blender 2.93.5
Posted: Sun Oct 31, 2021 10:14 pm
by kornflakekilla
error message i tried to remove and reinstall
Posted: Sun Oct 31, 2021 11:04 pm
I have the feeling you have downloaded the wrong package, have you downloaded from here (viewtopic.php?f=9&t=736) ?
Posted: Mon Nov 01, 2021 12:00 am
kornflakekilla wrote: Sun Oct 31, 2021 7:27 pm It wont detect my GPU even though its under system preferences. I have rtx 570 4th gen and it doesn't show up under devices and when I set it to render under GPU it doesn't change and stays with the CPU.
Did you try to do a final render? Your screenshot only shows the viewport, which by default uses the CPU even when you set GPU for final renders.
By the way the LuxCore GPU API settings are in the addon user preferences, the Blender/Cycles setting is not used by BlendLuxCore.
Posted: Mon Nov 01, 2021 1:31 pm
by kornflakekilla
Dade wrote: Sun Oct 31, 2021 11:04 pm I have the feeling you have downloaded the wrong package, have you downloaded from here (viewtopic.php?f=9&t=736) ?
Yes I did I thought I had to because it says id need to use an older version of blender for the other one!!
Posted: Mon Nov 01, 2021 1:32 pm
by kornflakekilla
B.Y.O.B. wrote: Mon Nov 01, 2021 12:00 am
Yes and nothing shows up I tried the same render using prorender and it showed up. And I tried to add the addon ill try again thank you!!
Posted: Mon Nov 01, 2021 2:54 pm
kornflakekilla wrote: Mon Nov 01, 2021 1:31 pm
Yes, correct.
