can't find "Performace tab"
Hi, i can't find "Performace tab". I need to check on tiled render, because i have 2 GPU 1660 super. I find up that the render time of 1 or 2 GPU's now is the same. I think becouse it using one big tile for whole render image. 1 tile = 1 GPU.
Re: can't find "Performace tab"
With multi-pass enabled, even if the image is a single big tile, different passes will be distributed to different GPUs so the multi-GPUs support will still work. However if you are using a single pass and one single tile, yes, only one GPU will be used.
