Noise threshold, no clue what's happening
juangea
Post by juangea »
So I'm testing Noise Threshold on windows with 2.6 but I noticed something weird, or I don't understand how it works or something is off.
I did some tests with noise threshold in one scene and I saw on the terminal how the "ToDo Pixels" amount was descending, I had a Samples Amount limit of 1024.
The noise threshold was configured at a high value on purpose, I had it to 150, and both the warmup and the test step samples to 16, I played with different values and I noticed no difference.
Then I went and disabled the Samples halt condition and I configured the Noise Threshold to 255, warmup and test to 16.
The render stopped at 1285 samples, shouldn't the noise threshold at 255 give me a super noise image, but near to instantaneous?
I mean, it's the biggest possible threshold, but I don't get a stop until sample 1285, and the result was as expected for that amount of samples.
Any ideas?
Re: Noise threshold, no clue what's happening
Are you using some kind of tile-like rendering with Sobol sampler ? Cache-friendly/Out-of-Memory settings ? Convergence threshold can work only with pure progressive rendering.
Can you post a test scene ?
juangea
Post by juangea »
Ah, that's the thing then.
I'm using Photon GI Cache, Sobol and Cache Friendly, it's the scene I sent you for the linux bug, you already have it :).
I'll test without Cache Friendly and come back.
juangea
Post by juangea »
Mmmh, there was not difference, having it configured at 255 gave me 1760 samples, and it was slower than before (I assume that it was because I was using progressive and not Cache Friendly).
Shouldn't I get a super noisy image?
behavior also depends on Warmup & Test Step samples
I found 8 satisfactory
juangea
Post by juangea »
Yes, I get that, but shouldn’t it stop the render after the first test with a threshold of 255?
Martini
Post by Martini »
juangea wrote: Tue May 18, 2021 7:30 am Yes, I get that, but shouldn’t it stop the render after the first test with a threshold of 255?
While the input is presented in levels (0-255) it is not based on output RGB colour space (0-255) but rather, the scaled raw float light intensity 0-Inf.
Imagine that 0.0-1.0 is the same as levels 0-255. If your light has realistic brightness (e.g. an HDR or Sun lamp) then it might be as high as 60000.0, which would be approximately 15,300,000 RGB levels. ;)
So if you have very bright lights and a lot of noise, it can take a long time to reduce noise down to the equivalent of even 255 above 0.
juangea
Post by juangea »
Then Noise Threshold is nearly useless in those situations?
Martini
Post by Martini »
juangea wrote: Tue May 18, 2021 4:06 pm Then Noise Threshold is nearly useless in those situations?
You might need to adapt it to your scene and use a higher value.
:idea: If you watch the console output while it's rendering, it will tell you the current noise value. When you reach the desired (visual) noise level, that is your threshold.
[LuxCore][188.640] Convergence test: ToDo Pixels = 1, Max. Error = 1.19853 [306.823/256]
E.g. if I was happy with the noise level when it printed this message, I would use the threshold 306.823
For reference, this is my scene with an HDR with halt condition at noise threshold 255:
juangea
Post by juangea »
The thing is that in Blender we cannot put more than 255 I think.
@Theverat should know better I imagine.
P.S.: Yep, I just confirmed, in Blender the maximum value is 255, we cannot configure higher values.
P.S.2.: To Theverat (BYOB) I just changed the maximum limit of Noise Threshold from "max" to "soft_max" to allow freedom in maxmium written value, may be a thing to consider so the gates are open for custom values, what do you think?
