shape modifiers
Posted: Fri May 07, 2021 9:29 pm
by val2
I'm trying to use the shape modifiers but I can't get them to behave. I am attaching an image show a simple low poly sphere that I place a height displacement and a subdivision modifier. the displacement works but the underlying mesh shows up as a series of broken planes. AmI doing something wrong or is it a bug?
thanks,
Val
Re: shape modifiers
Posted: Fri May 07, 2021 11:16 pm
This should happen only if sphere "tiles" do not share border edges (i.e. they are duplicated). Can you post a test .blend ?
Re: shape modifiers
Posted: Sat May 08, 2021 12:05 am
by val2
Ha, I worked it out. If shade smooth is on it works. If shade flat is on it tiles like the example.
Re: shape modifiers
Posted: Sat May 08, 2021 11:17 am
val2 wrote: Sat May 08, 2021 12:05 am
Yes, because flat shade requires to duplicate the sharp edges (i.e. you have different normals on each side of the edge).
