[SOLVED] Hair material
Posted: Thu Dec 10, 2020 12:53 pm
by Leandro Oliveira
Hi guys!
I´m trying to make "fur" for a rug. In Cycles, it´s possible to use the material of the emitter, in the hair. I noted that this is possible in Lux, too, but hair keep rendering in black color. How can I fix it?
I´m using Lux 2.5 Beta1
Re: Hair material
Posted: Thu Dec 10, 2020 2:05 pm
Please read and follow the forum rules in the red box above.
Re: Hair material
Posted: Thu Dec 10, 2020 5:22 pm
by Leandro Oliveira
Sorry. Here´s the file.
testRug.blend
(2 MiB) Downloaded 314 times
Thanks.
Re: Hair material
Posted: Fri Dec 11, 2020 12:03 pm
by DionXein
Leandro Oliveira wrote: Thu Dec 10, 2020 12:53 pm I´m trying to make "fur" for a rug. In Cycles, it´s possible to use the material of the emitter, in the hair. I noted that this is possible in Lux, too, but hair keep rendering in black color. How can I fix it?
Man, it's all onto bump. Also in Cycles usually used second material, like Principle Hair (it's optimised for strands rendering). So If you want your carpet using bump create separate material for particle system.
Re: Hair material
Posted: Fri Dec 11, 2020 12:05 pm
by Leandro Oliveira
@DionXein, thank you, man! :)
