Rendering
Posted: Tue Nov 03, 2020 5:11 pm
by Skilled420
Is there a fixed speed for rendering, because my samples only go up by 1 every time the film refreshes.
Re: Rendering
Posted: Tue Nov 03, 2020 5:17 pm
No, rendering speed depends on your scene configuration and the hardware you have available.
If your samples go up that slowly, your scene might be very hard to render, or your hardware is very slow. Can you give us more details about both?
Re: Rendering
Posted: Tue Nov 03, 2020 5:49 pm
by Skilled420
My scene isn't that complex it's just a cup with water in it. I think my pc is just trash (No Gpu and a somewhat slow and outdated Cpu)
Re: Rendering
Posted: Tue Nov 03, 2020 5:58 pm
Skilled420 wrote: Tue Nov 03, 2020 5:49 pm
Maybe we can help improve renderspeed if you share more about it
Re: Rendering
Posted: Tue Nov 03, 2020 6:30 pm
by Skilled420
It is a Cup with Water in it. I'm planning to add ice cubes, water bubbles and water vapour to it. I am also using Caustics.
Re: Rendering
Posted: Tue Nov 03, 2020 6:33 pm
Skilled420 wrote: Tue Nov 03, 2020 6:30 pm
I mean the blendfile if it is not too private for you
Re: Rendering
Posted: Wed Nov 04, 2020 2:38 pm
by Skilled420
Here is the blend file:
https://drive.google.com/file/d/1uJ-EYg ... sp=sharing
How do I also get rid of the black parts of the glass?
Re: Rendering
Posted: Wed Nov 04, 2020 3:17 pm
I'm getting 1.6 M samples/sec here on a Ryzen 7 2700x, which is quite high samples/sec for Bidir. So the slowness on your side is most likely due to your hardware.
I would recommend to re-create your glass and liquid materials using LuxCore nodes, because you will need to use the volume priority setting to handle the overlapping glass and liquid correctly. I have done that in the attached .blend file. (also, Cycles procedural textures are not supported in LuxCore)
Skilled420 wrote: Wed Nov 04, 2020 2:38 pm
You need to raise the max. path depth:
Re: Rendering
Posted: Wed Nov 04, 2020 4:12 pm
by Skilled420
How would I create something that looks like this:
Re: Rendering
Posted: Wed Nov 04, 2020 4:21 pm
A nice tutorial theme
will think about it.
