Nk metal profile
Posted: Fri Oct 30, 2020 10:16 am
Do anyone know where i can download some nk metal profike to use with luxcore shader ?
Re: Nk metal profile
Posted: Fri Oct 30, 2020 11:03 am
by CodeHD
There seem to be some lists here:
https://github.com/ulfgri/nk/tree/master/sopra (sopra files)
http://luxpop.com/RefractiveIndexList.html (Luxpop files)
Posted: Fri Oct 30, 2020 11:15 am
by Dez!
i tried several.
some did not allow the render to start.
others look like nothing black.
Posted: Fri Oct 30, 2020 11:16 am
by CodeHD
yeah I've just tried, too.
The sopra files return "bad header", and the luxpop are just black...
Posted: Fri Oct 30, 2020 11:19 am
by CodeHD
EDIT: This post was wrong
Posted: Fri Oct 30, 2020 11:41 am
I found nk data included with Maxwell & Indigo working fine.
Posted: Fri Oct 30, 2020 11:59 am
by Dez!
show what happens?
I tried removing the code below, but only black on the render.
Posted: Fri Oct 30, 2020 12:05 pm
Dez! wrote: Fri Oct 30, 2020 11:59 am show what happens?
Same here .
by CodeHD
Actually I was wrong there (bad choice of data files)
Upon resinpection I found another problem: For example the CoO.nk file does not go into the visible spectral range, it only has UV and below, so LuxCore doesn't have data to work with.
