Page 1 of 2
LuxCore Network Render
Posted: Thu Jul 16, 2020 10:09 pm
by Jack Eden
MacOS 10.14.6
BlendLuxCore 2.4 beta1
When I launch LuxCore Network Render from inside of blender and then open a NetConsole window and then "add job" I am not able to select the .cfg file. All the files are greyed out. See attached image. Has anyone else encountered this before? I've attached a screenshot of the file browser window.
Re: LuxCore Network Render
Posted: Thu Jul 16, 2020 11:31 pm
by Shantarli
Save as binary, it will generate .bcf file which you will be able to select.
Posted: Fri Jul 17, 2020 5:27 am
by Jack Eden
Thank you. Such an easy fix, and this is specified in the Wiki, but I just didn't notice it.
A little bit of a follow up question now that I have the Network Render option working, I can't get the external Network Render to look the same as the image when rendered internally. I have Color Management set to have everything turned off, I think anyway, but the external render still looks significantly darker than the internal render. Any chance you have come across this issue also?
Posted: Fri Jul 17, 2020 7:16 am
Jack Eden wrote: Fri Jul 17, 2020 5:27 am
It may be something related to gamma setting, try to export the scene in text format and post here the .cfg so we can see how the image pipeline is configured.
Posted: Fri Jul 17, 2020 2:34 pm
by Jack Eden
Thanks for the quick reply. I've attached an image comparing the internal and external render, and also the .cfg file, however the external render was run from a binary .bcf file, but I exported the .cfg file immediately afterward and didn't change any settings.
Posted: Sun Jul 19, 2020 10:16 am
Jack Eden wrote: Fri Jul 17, 2020 2:34 pm
The imagepipeline defined in the .cfg looks normal with tonemapping and gamma 2.2.
I have done a simple test with Blender and a simple cube-over-plane scene: I get the same output inside Blender and outside Blender with an exported scene (with LuxCoreUI, Network rendering, etc.).
Can you do the same test with a fresh scene ? You may have some setting different from Blender default in your scene. Note: my default Blender "Color Management => View Transform" is set to "Filmc", yours seems set to "Standard".
Posted: Mon Jul 20, 2020 7:48 pm
by Jack Eden
Dade wrote: Sun Jul 19, 2020 10:16 am
I tried a fresh scene with just the cube and everything behaved normally. I'll continue to test to see if I can figure out what is causing the anomaly in that particular scene.
I've tried to find documentation about how to launch PyLuxCore NetNode via command line (I want to be able to launch on a headless computer via SSH) but I can't find anything, and I'm not quite computer savvy enough to just know how. Is it possible to use other computers that are headless to contribute to the render through a command line?
Posted: Tue Jul 21, 2020 9:18 am
Jack Eden wrote: Mon Jul 20, 2020 7:48 pm
Linux ? I assume all render node are on the same local network. Download and unpack the standalone version and run something like:
python3 pyluxcoretools.zip netnode
"netnode" command is the headless version of ""netnode
ui".
P.S. if it isn't an Ubuntu, you may have to use "python" instead of "python3" but be sure it is python v3.x and not python v2.x.
Posted: Sat Jul 25, 2020 5:47 pm
by Jack Eden
Thanks again for your very patient replies. I really want to get LuxCoreRender to function for my workflow and I am really struggling with this, but I hope that I am not being too annoying with so many questions. My basic workflow is to render many different individual images, not animations, so ideally I am able to create the scene files in blender and then render them externally so that blender is not tied up with rendering and I can get to working on the next scene for export. This was really easy in the previous version "LuxRender" as I would just export scene files and add them to the LuxRender queue. I know the same is possible in LuxCoreRender, I just can't seem to get it to function.
I have not been able to get PyLuxCoreTools to work on Ubuntu 20.04. I have two computers running Ubuntu 20.04, one was upgraded from a previous ubuntu version and one is a clean install of 20.04 and I am having the same problem on both of them.
I have followed the instructions I found on GitHub - LuxCoreRender and installed Python3
and then I tried running
but that didn't work because I got an error that PySide is only supported up through Python 3.4 and the default download for Python is now v3.8, so then I ran the command
and that installed without an error. But then when I tried running
I got the errors "numpy.core.multiarray failed to import" and "numpy.core.umath failed to import". After doing a little bit of reading it seems that the error may be caused because of multiple versions of python installed. But I'm also wondering if I need a lower version of Python that only uses PySide and not PySide2, but it seems like PySide2 is the version that works for MacOS so maybe I'm wrong about that. It seems like LuxCoreRender is very difficult for an artist to install and use, but maybe not so difficult for a computer software engineer. And so I'm sorry for asking so many questions, but I really do spend many hours of research before coming back to the forums and bothering all of you.
Also, from Blender 2.82a running BlendLuxCore 2.4rc1 (Ubuntu 20.04) nothing happens when I click the LuxCore Network Render button, the computer just freezes momentarily and the fan spins up for a few seconds, and then it is as if I didn't click the button at all. I am assuming that whatever is causing the "pyluxcoretools" error is also not allowing "LuxCore Network Render" to launch from within Blender.
Posted: Sat Jul 25, 2020 9:12 pm
by acasta69
Numpy is another package needed by luxcore, you can install it with
