Its a rainbow.
Theo_Gottwald
Its a rainbow.
Post by Theo_Gottwald »
Now this is a nice example Scene,
you just need to remove the Color-Correction Node in the Composer then it works fine.
V2-Film.blend
(220.07 KiB) Downloaded 296 times
Last edited by Theo_Gottwald on Mon Jun 29, 2020 2:27 pm, edited 3 times in total.
Re: No its not a rainbow.
Could you upload a rendered picture of one of the frames that show the issue?
Theo_Gottwald
Now its a rainbow.
You can disregard it.
It was a to dark setting of the color-correction node in the Composer.
In such case the in between colors fade away and just RGB is left.
Good to know.
