Out of Core.How its work
Posted: Thu Jun 04, 2020 1:56 pm
by PetrT
Hi
Try to use Out of Core
Can not figured out how to set up to render it right
In this mode it renders by 16*16 tiles but how to set render full image
If set in halt conditions for example 600 samples
it indicates and render 600 tiles
Is it description how to use it
Re: Out of Core.How its work
Posted: Thu Jun 04, 2020 2:02 pm
PetrT wrote: Thu Jun 04, 2020 1:56 pm In this mode it renders by 16*16 tiles but how to set render full image
It should render something similar to one tile at time, doesn't it ?
Posted: Thu Jun 04, 2020 2:12 pm
by PetrT
it renders part of image
16*16 its my opinion may be i am wrong
but the question is how to set params of render panel to render it full
because if halt condition set to 600 samples
and supersampling 16 it renders about half of image 1080*1080
Posted: Thu Jun 04, 2020 2:58 pm
PetrT wrote: Thu Jun 04, 2020 2:12 pm it renders part of image
Under the "Sampling" panel there is the information of how many samples per pass you are going to have:
So you can use an halt condition of 512, 1024, etc. with the default settings.
Posted: Thu Jun 04, 2020 3:32 pm
by PetrT
ok
made some tests
and if only GPU used it works well
CPU+GPU part of image is not rendered
Posted: Thu Jun 04, 2020 6:47 pm
PetrT wrote: Thu Jun 04, 2020 3:32 pm CPU+GPU part of image is not rendered
Yes, it is a known problem, it is not possible to known the amount of samples for CPUs+GPUs.
Posted: Thu Jun 04, 2020 8:34 pm
by PetrT
Thank you
This makes this situation clear
