Volume sampling
Posted: Mon Apr 27, 2020 1:42 pm
Ok ! i decide to work on a short animation i have in mind for a while now. but i'm encountering an issue i've already seen multiple time on different project.
The issue
As soon as you get some smoke / or volumetric light / dust in a scene luxcore converge way slower than cycles. And mostly inside of thoses volumetric area.
My scene
this scene is optimized for animation i shouldn't exceed 5 min rendertime if i want this to become a reality. but as soon as i add my volumetric box BOOM convergence become seriously slow. 1H45mn for this
the test scene
so i create i small test scene for both cycles and luxcore.
Luxcore
The Blend
volume test.blend
(697.9 KiB) Downloaded 486 times
Cycles
Maybe an idea
Cycles have separate setting for volume max bounce (it is set to 0 by default) and it is really fast at 0. become a bit slower at 12. but still faster than luxcore.
Re: Volume sampling
Posted: Mon Apr 27, 2020 1:56 pm
Depending on your hardware (CPU) you should change the halt time to match cycles time.
Re: Volume sampling
Posted: Mon Apr 27, 2020 2:05 pm
If it isn't yet evident, I will not look in anything else until when I'm out of the "white rabbit hole" (i.e. CUDA, Out-of-Core rendering, new Random/Sobol sampler for (mostly) OoC).
Re: Volume sampling
Posted: Mon Apr 27, 2020 2:44 pm
Dade wrote: Mon Apr 27, 2020 2:05 pm If it isn't yet evident, I will not look in anything else until when I'm out of the "white rabbit hole" (i.e. CUDA, Out-of-Core rendering, new Random/Sobol sampler for (mostly) OoC).
Sure I understand that. but make a while i have to report this. also as my project is in development i can wait until final rendering become urgent.
from here to the point all get finish there is time.
Re: Volume sampling
Posted: Tue Apr 28, 2020 8:37 pm
by fluxfish
Just a first pic and maybe more details will get done but I would spend the black-yellow-column right-side in the back a bit more wear-and-tear, a to clean and new appearance in garage-surroundings is sort of boring and unnatural, deflects attention - the most shiny thing will be that monster machine.
