Flickering video
Posted: Mon Apr 20, 2020 11:47 am
by rickyx
I would like to make a small FullHd video with this file, having a reasonable rendering time.
This is a first rehearsal:
0001-0049.mp4
(1.41 MiB) Downloaded 596 times
It came discreetly but the denoise causes artifacts and flickering.
Do you have any suggestions on how to avoid them?
Also, I don't know if it's a bug, if I activate PhotonGI Cache the denoiser pass gets black.
I'm on Linux, Blender 2.82, Lux 2.3.
Here is the file:
Natural_HistoryRicsLux2.82-E.blend
Pano video
(2.92 MiB) Downloaded 609 times
Thank you,
Riccardo
Re: Flickering video
Posted: Mon Apr 20, 2020 12:46 pm
You could try:
  • Use Sobol sampler instead of Metropolis (Metropolis is very slow on GPUs)
  • Disable multiscattering in the world volume
  • Enable the environment light cache
In general, if the denoiser causes artifacts and flickering, you need to render more samples.
Posted: Tue Apr 21, 2020 10:16 am
by rickyx
Thank you,
I tried: it reduces the problem of the denoise on the distant parts but white spots appear that go around.
I try to double the calculation time.
Posted: Tue Apr 21, 2020 10:20 am
They may be denoised fireflies, how does the not-denoised frame look ? Are you using variance clamping ?
Posted: Wed Apr 22, 2020 10:51 pm
by rickyx
Clamping was disabled.
Enabling it (and passing from 10min to 16min ) has greatly improved the quality:
Much better! (Compressed frame)
Here is the non denoised frame:
Here my final setup:
(2.88 MiB) Downloaded 1128 times
Thank you,
Riccardo
