Displacement: mismatch between viewport and final render
Posted: Sun Mar 29, 2020 6:08 pm
Viewport and final are not matching each other.
Blend :
Antelope__cayon.blend
(2.07 MiB) Downloaded 327 times
Re: Displacement: mismatch between viewport and final render
Posted: Sun Mar 29, 2020 6:20 pm
You have to apply the scale on the object with displacement, then multiply the displacement height with the applied scale (i.e. 10 in this case).
Posted: Sun Mar 29, 2020 6:27 pm
I'm honestly considering to export every object with scale != 1 as instance even in final render at this point, because of tons of mismatches between render and viewport like this one.
Posted: Sun Mar 29, 2020 6:36 pm
What Covid19 remedy :lol:
More seriously this isn't a long term solution. I like the current viewport behaviour.
Wanted to make a Tutorial about it but this behaviour add a complexity layer we shouldn't have or teach to someone.
Posted: Sun Mar 29, 2020 6:47 pm
BuUUUT Am I sure to be alive 5 days from now with this time at my disposal :lol:
going to make the tutorial right now :mrgreen:
Posted: Mon Mar 30, 2020 9:55 am
Now it is a mismatch between texture transformation displacement. normally it should be stretched.
antelope__canyon.blend
(2.03 MiB) Downloaded 306 times
Posted: Mon Mar 30, 2020 10:16 am
final and viewport look identical to me, am I missing something?
Posted: Mon Mar 30, 2020 10:25 am
B.Y.O.B. wrote: Mon Mar 30, 2020 10:16 am final and viewport look identical to me, am I missing something?
yes you miss. i mean in the viewport displacement doesn't match the voronoi texture stretching. connect the displacement node to see if it match texture transformation.
Posted: Mon Mar 30, 2020 10:31 am
My bad i didn't select the right mapping transformation mode (Should be UV not Global)
Posted: Mon Mar 30, 2020 10:40 am
I think there's a bug here.
