I have a nvidia gpu i cant choose it .
Its either cpu or opencl which both use cpu.
Also does blender node work with luxrender ? It says not all node are supported will all nodes be supported in the future?
Where do i set up samples, it just render forever.
How do u use gpu render
Re: How do u use gpu render
Set the engine to path, device to OpenCl, then choose your GPUs in the performance panel.Ghjj wrote: Wed Oct 30, 2019 8:16 pm I have a nvidia gpu i cant choose it .
If they don't show up, you will have to check your OpenCL installation, you could try to reinstall your GPU driver.
See the list here: https://github.com/LuxCoreRender/BlendL ... issues/272Ghjj wrote: Wed Oct 30, 2019 8:16 pm Also does blender node work with luxrender ? It says not all node are supported will all nodes be supported in the future?
In the render properties, "LuxCore Halt Conditions" panel.
