Bump on OpenCL
Posted: Tue Sep 24, 2019 5:13 pm
Would it be possible to make mix material get normal/bump map info straight from materials instead of using the bump slot on mix material node, it is rather unintuitive. It gets more complex when using pointer to use materials for mixing because there is no way to access normal maps form inside pointer nodes to then do the mixing.
