Bump on OpenCL
Egert_Kanep
Bump on OpenCL
Post by Egert_Kanep »
Would it be possible to make mix material get normal/bump map info straight from materials instead of using the bump slot on mix material node, it is rather unintuitive. It gets more complex when using pointer to use materials for mixing because there is no way to access normal maps form inside pointer nodes to then do the mixing.
Re: Bump on OpenCL
It is possible but ping me about this problem after v2.2 release.
Egert_Kanep
Re: Bump on OpenCL
Will do that
