Page 1 of 2
glossy edges
Posted: Wed Aug 07, 2019 5:51 am
This is a problem I reported long ago but now that we have a disney shader we can finaly compare to how things should look at object edges..
look at the weird darkening of glossy:
and now disney:
Re: glossy edges
Posted: Wed Aug 07, 2019 6:50 am
by FarbigeWelt
lacilaci wrote: Wed Aug 07, 2019 5:51 am
and now disney:
Honestly, I do not see what you mean. Please copy relevant parts from both versions into one image and mark them clearly. Thanks.
Re: glossy edges
Posted: Wed Aug 07, 2019 7:39 am
FarbigeWelt wrote: Wed Aug 07, 2019 6:50 am
and now disney:
Really? You don't see any difference?
here, glossy shader in the red rectangle, outside of it is disney:
Re: glossy edges
Posted: Wed Aug 07, 2019 8:50 am
Yes there is a thin dark line at the edge.
Re: glossy edges
by FarbigeWelt
lacilaci wrote: Wed Aug 07, 2019 7:39 am
and now disney:
Thank you much for the eye opener in the early morning!
Do not be shocked, spotting the difference at a smartphone display zooming and moving around is not easy if you do not know what you are looking for. At home at 27“ I may have seen what you mean just in a glimpse...
Anyhow, this dark edges are agreedly odd. Looks like enhanced shadow but that makes not any sense, does it?
Re: glossy edges
Posted: Wed Aug 07, 2019 9:04 am
FarbigeWelt wrote: Wed Aug 07, 2019 8:50 am
Ah yes, on a phone it might be a little problem to spot...
Anyways, it's definitely a problem with the glossy shader... Corona had this type of issue for a long time too afaik
Re: glossy edges
Posted: Wed Aug 07, 2019 9:05 am
So use Disney instead of Glossy2 material, why not
Re: glossy edges
Posted: Wed Aug 07, 2019 9:11 am
Dade wrote: Wed Aug 07, 2019 9:05 am
Yes, definitely. I would use it instead both glossy and matte. Disney is usable for most of materials in cycles too, but they have a bit more advanced implementation which will be probably even more upgraded in near future.(I think some thin translucency will be added)
Re: glossy edges
Posted: Wed Aug 07, 2019 9:25 am
lacilaci wrote: Wed Aug 07, 2019 9:11 am
Yes, they have the SIGGRAPH 2015 additions (i.e. the additional transmission related parameters) while we have the original SIGGRAPH 2012 implementation. But it is not something particularly hard to add in a near future.
Re: glossy edges
Posted: Wed Aug 07, 2019 12:59 pm
by Fox
Can the Disney model be used for rough glass?
