glossy edges
glossy edges
This is a problem I reported long ago but now that we have a disney shader we can finaly compare to how things should look at object edges..
look at the weird darkening of glossy:
and now disney:
Re: glossy edges
lacilaci wrote: Wed Aug 07, 2019 5:51 am This is a problem I reported long ago but now that we have a disney shader we can finaly compare to how things should look at object edges..
and now disney:
Honestly, I do not see what you mean. Please copy relevant parts from both versions into one image and mark them clearly. Thanks.
Re: glossy edges
FarbigeWelt wrote: Wed Aug 07, 2019 6:50 am
and now disney:
Really? You don't see any difference? :shock:
here, glossy shader in the red rectangle, outside of it is disney:
Re: glossy edges
Yes there is a thin dark line at the edge.
Re: glossy edges
lacilaci wrote: Wed Aug 07, 2019 7:39 am
and now disney:
Thank you much for the eye opener in the early morning! :D
Do not be shocked, spotting the difference at a smartphone display zooming and moving around is not easy if you do not know what you are looking for. At home at 27“ I may have seen what you mean just in a glimpse...
Anyhow, this dark edges are agreedly odd. Looks like enhanced shadow but that makes not any sense, does it?
Re: glossy edges
FarbigeWelt wrote: Wed Aug 07, 2019 8:50 am
Ah yes, on a phone it might be a little problem to spot...
Anyways, it's definitely a problem with the glossy shader... Corona had this type of issue for a long time too afaik
Re: glossy edges
So use Disney instead of Glossy2 material, why not :?:
Re: glossy edges
Dade wrote: Wed Aug 07, 2019 9:05 am So use Disney instead of Glossy2 material, why not :?:
Yes, definitely. I would use it instead both glossy and matte. Disney is usable for most of materials in cycles too, but they have a bit more advanced implementation which will be probably even more upgraded in near future.(I think some thin translucency will be added)
Re: glossy edges
lacilaci wrote: Wed Aug 07, 2019 9:11 am but they have a bit more advanced implementation which will be probably even more upgraded in near future.(I think some thin translucency will be added)
Yes, they have the SIGGRAPH 2015 additions (i.e. the additional transmission related parameters) while we have the original SIGGRAPH 2012 implementation. But it is not something particularly hard to add in a near future.
Fox
Re: glossy edges
Post by Fox »
Can the Disney model be used for rough glass?
