Glossy with Object Motion Blur bug
Posted: Wed Feb 14, 2018 4:29 pm
If Camera Motion Blur is active (on) then Glossy reflection gets corrupt, is stuck to surface & shading goes flat...
(BlendLuxCore alpha4, w7)
eg
1. Motion Blur ON :shock:
2. Motion Blur OFF :D
EDIT/ scene file attached
Atollo238_bug.zip
(842.96 KiB) Downloaded 560 times
Re: Glossy with Camera Motion Blur bug
Posted: Wed Feb 14, 2018 5:56 pm
This is likely to happen because some error in UV transformations, going to check.
Posted: Wed Feb 14, 2018 6:10 pm
In your .blend file, only object motion blur is enabled, not camera motion blur.
Just saying because you wrote "Camera Motion Blur" in your post.
Posted: Wed Feb 14, 2018 6:43 pm
B.Y.O.B. wrote: Wed Feb 14, 2018 6:10 pm In your .blend file, only object motion blur is enabled, not camera motion blur.
oh, my bad, fixed the title ;) thanks
Re: Glossy with Object Motion Blur bug
Posted: Thu Feb 15, 2018 1:44 am
narrowed down to Object (bug only appears when Object is checked/enabled)
ps
used an updated BlendLuxCore from current master
edit: above mentioned build crashes instantly when rendering with OCL (noticed it first when i tested the updated pyluxcore.pyd) :?
Posted: Thu Feb 15, 2018 12:08 pm
It should be an OpenCL-only bug. This is a rendering with PATHCPU:
and this with PATHOCL:
Going to track it.
Posted: Thu Feb 15, 2018 1:08 pm
Dade wrote: Thu Feb 15, 2018 12:08 pm It should be an OpenCL-only bug. This is a rendering with PATHCPU:
Going to track it.
So am back to official alpha4
& IDK... i get even worse result switching to CPU
ie. first frame renders OK (as yours), but on the next frame partial geometry simply disappears (also in LuxCore display) :?
eg.
Posted: Thu Feb 15, 2018 8:25 pm
There were 3 problems. One was general when rendering any anisotropic material (metal, glossy, etc. with uroughness != vroughness) on GPUs. The second was about motion blur support on CPUs. I fixed both:
The last one: https://github.com/LuxCoreRender/LuxCor ... ry.cpp#L77
I guess it is time to write the motion blur support there :mrgreen:
Posted: Thu Feb 15, 2018 9:06 pm
At least something good out of it all comes... Small victories! :D
TYVM
Posted: Fri Feb 16, 2018 11:23 am
I should have fixed everything, this is the original animation posted:
and this with a bit less "purple-ness":
